Back to List
RLL Racing Stays Connected from Headquarters to Every Race with Peplink
As a championship-winning INDYCAR and IMSA racing team, Rahal Letterman Lanigan (RLL) Racing relies on real-time data and video across its headquarters and trackside operations. Peplink provides the network backbone that connects these distributed locations as one unified network, regardless of the connectivity available at each race venue.
Summary
Organization
Rahal Letterman Lanigan Racing (INDYCAR and IMSA racing team)
Application
Real-time race telemetry and camera feed distribution between trackside and headquarters
Solution Provider
Crosstalk Mobile (Peplink Reseller)
Peplink Deployment
Balance 1350 EC, 48 PoE 2.5G Switch, Balance 310X, BR2 Pro, BR1 Pro 5G, AP Pro AX, InControl, and SpeedFusion
Project Scope
One core network at headquarters and portable network deployments across race-day locations
Outcome
18-hour network migration, reliable and portable connectivity across every race location, and $80,000 saved over three years
The Challenge
One High-Performance Network. Every Race. No Two Alike.
The Solution
Bridging Every Location with SpeedFusion
The Result
An 18-Hour Migration, $80,000 Saved, and a Network Ready for Every Race and the Future
Testimonials
Every single piece that I would expect to work really has. We can always build onto it, but this is a rock solid foundation to build for the future.
Andrew Hughes
Layer 2 bridging reliably in real time over a bonded mix of fiber, 5G, Starlink, and Wi-Fi that's different at every location and prone to failure. That's where SpeedFusion pulls ahead and that's the part other vendors can't keep up with.
Chris Sherwood
Deployment Architecture
Featured Products
Balance 1350 EC
Used to replace aging core network at headquarters
Handles 2 Gbps SpeedFusion VPN throughput and 800 peers, covering every truck and stand
Dual hot-swappable power supplies keep the network up if one supply fails
Switch Series
Added to core network racks to replace legacy switches
Deployed in engineering trucks and stands to power on-site peripherals
Runs 1 or 2.5 Gbps on select ports, suited for access control or more demanding devices
Balance 310X
Deployed as the main router inside each engineering truck at the track
Connects to a switch and the AP Pro AX for outdoor antenna coverage
Rugged, fanless design that operates through heat and vibration
AP Pro AX
Paired with the engineering truck's Balance 310X router
Extends wireless coverage from the truck across the surrounding paddock area
Rugged and waterproof housing built to sit outside at any track
BR2 Pro
Deployed to the timing stand and other paddock trucks
Runs on a dedicated Starlink while still joining the same shared network
Built with dual embedded 5G modems enabling cellular redundancy
BR1 Pro 5G
Provided at the viewing stand and fuel rig
Pulls Wi-Fi as WAN from nearby timing stand
Compact form-factor for smaller-footprint race-day locations
InControl - Cloud Management
Accessed through PrimeCare, bundled licensing and warranty subscription
Gives RLL one dashboard to configure every device for any location
Removes the need for a technical team to configure each router on-site
SpeedFusion Technology
Establishes tunnels linking every location back to headquarters
Bonds or fails over between fiber, 5G, Starlink, and Wi-Fi for a reliable network
Keeps every location on one shared Layer 2 network, no matter its physical connection
FAQs
Q1. How does Peplink support racing connectivity?
A.
Q2. How can multiple Peplink devices be managed across different locations?
A.
Q3. What connections can be used with Peplink devices?
A.
Q4. Can Peplink hardware be used outdoors, like for trackside environments?
A.
Q5. What Peplink products are recommended for racing or live event connectivity?
A.
Next Steps
Talk to a Specialist
Share Your Story
