Built for Satellite-Based Networks
Bond multiple satellite constellations into a single, resilient connection for enterprise-grade throughput and seamless failover.
The Challenge
Scaling Satellite Connectivity for Enterprise Demands
Bandwidth Ceiling
A single satellite connection has a finite data rate. High-density deployments often require gigabit throughput to support large numbers of users and cloud-based applications.
Performance Variability
Orbital handovers, obstructions and environmental conditions can impact link stability, making it difficult to maintain the high uptime and consistent performance required for critical applications.
Operational Complexity
Managing multiple satellite services across different providers makes it challenging to maintain unified visibility and control across distributed deployments.
The Peplink Advantage
Purpose-Built for Multi-Orbit
Peplink doesn't just switch between satellites. It integrates them.
Peplink Multi-Orbit Routers are engineered to optimize the performance of satellite networks, transforming individual links into a unified, reliable, high-bandwidth connection that meets the strictest enterprise standards.
Core Capabilities
Bandwidth Bonding
Greater Speed & Reliability
Bond multiple satellite connections into a single high-speed, resilient link.
Traffic is distributed at the packet level so every session benefits from all available bandwidth.
SpeedFusion Boost
Maximized Throughput
Sustain high throughput across lossy and unpredictable connections.
File transfers, web apps and cloud access are optimized automatically under challenging conditions.
Hot Failover
Uninterrupted Connectivity
Combine different satellite connections to eliminate dead zones and provide automatic, sub-second backup.
Critical applications continue without interruption, even if any individual link drops.
Satellite & 5G Integration
Hybrid Network Flexibility
Incorporate external 5G into satellite deployments to create a more resilient and adaptable network.
Balance traffic across satellite and 5G links to expand uptime, enhance performance, and control costs.
SpeedFusion Score
Strategic Optimization
Go beyond raw megabits to real-time evaluation of network health and performance.
Use these actionable insights to instantly pinpoint performance gaps and uncover clear paths to finetune your connection mix.
InControl
Centralized Management
Monitor and manage every satellite network, such as Starlink, OneWeb and Iridium, from a single dashboard.
Gain visibility into performance and streamline management at scale.
Product Lineup
MAX Orbit Series
Purpose-Built for Robust Multi-Orbit Connectivity
View Product DetailsMAX Orbit 2
MAX Orbit 4
MAX Orbit 8
Ready to Scale Beyond a Single Link?
Build a resilient, gigabit-class satellite network with Peplink today.
