Common Features
5G Ready
5G can reach speeds 10x faster than 4G LTE. Download movies in just seconds.
IP68 Rated and UV proof
Certified quality protection from dust, water, and UV allows you to use it even in poor weather conditions.
B71 Support
Supports extended bandwidth range, including B71.
7dBi High Gain
Increased signal strength for a stronger connection and less interference.
Which antenna is right for you?
- Understand the Name -
Mobility 82G
8x Cellular | 2x Wi-Fi | 1x GPS
With 8 cellular channels, 2 Wi-Fi and a GPS, the Mobility 82G has an ultra-high gain and supports dual 5G modems in a single chassis. It keeps critical missions connected over longer distances.
The Mobility 82G is an all-in-one antenna ideal for long-range transmissions, enabling first responders and mobile healthcare providers to extend their services to more remote locations.
Mobility 42G
4x Cellular | 2x Wi-Fi | 1x GPS
With 4 cellular channels, 2 Wi-Fi and a GPS, the Mobility 42G provides ultrawide bandwidth within a single antenna housing. The Mobility 42G is designed for heavy network usage and solid reliability.
The Mobility 42G is an all-in-one antenna ideal for large scale deployments in transportation, public safety and maritime operations.
Mobility 40G
4x Cellular | 1x GPS
With 4 cellular channels, the Mobility 40G is a powerhouse capable of delivering high bandwidth and solid reliability under heavy use. Equipped with high gain LNA, the GPS receiver has improved location tracking.
The Mobility 40G is ideal for large-scale public safety, mobile healthcare, mobile command, and other operations using a large volume of data.
Mobility 22G
2x Cellular | 2x Wi-Fi | 1x GPS
With 2 cellular channels, 2 Wi-Fi, and a high gain LNA GPS, the Mobility 22G is a versatile all-in-one cellular antenna solution. It has 2x2 MIMO and dual-band Wi-Fi for high bandwidth and solid reliability.
The Mobility 22G is ideal for small-scale public safety and transportation connectivity.
Mobility 20G
2x Cellular | 1x GPS
The Mobility 20G comes with 2 cellular channels and 1 high gain LNA GPS built for reliable LTE or 5G connectivity. Housed in a robust exterior, this antenna can provide high bandwidth for mobile applications.
The Mobility 20G is ideal for small-scale public safety, mobile healthcare, and transportation connectivity.
Mobility 02
2x Wi-Fi
The Mobility 02 is a low-cost, dual-band Wi-Fi antenna built for mobile applications. It comes with 2x2 MIMO that provides you with a high bandwidth and solid reliability despite its price.
The Mobility 02 is ideal for maintaining a strong signal strength when various obstructions may weaken or block Wi-Fi signals.
Premium Deck Mount
Rugged and heavy duty mounts are intended for deck and mast installations. The cable is protected inside the mount with direct feed through the deck or mast.
This mount is made from the highest quality Marine Grade Stainless Steel to withstand harsh weather conditions and prevent corrosion at sea.
Extension Cables
A full array of UV stabilized and low-loss extension cable options with different connectors and lengths to meet any of your antenna needs.
Peplink Antenna Application Brochure
More Possibilities Than You Can Imagine
Discover different scenarios where you can benefit from our antennas,
not just what's implied by their names.
