Common Features
5G Ready
5G can reach speeds 10x faster than 4G LTE. Download movies in just seconds.
IP68 Rated and UV Proof
Certified quality protection from dust, water, and UV allows you to use it even in poor weather conditions.
Designed for Long Range
Increased signal strength for a stronger connection and less interference.
GPS Support*
Includes active and high performance GPS receiver ideal for location tracking.
* Excluding Maritime 10.
Which antenna is right for you?
- Understand the Name -
Maritime 10
1x Cellular
With 9.3dBi gain, the Maritime 10 is a single-cellular antenna that can keep you connected even farther away from the shore. Small and 5G ready, this antenna is a future-proof choice for any maritime applications.
*Cable is not included.
Maritime 20G
2x Cellular | 1x GPS
With 2 cellular channels, the Maritime 20G is a 5G-ready antenna to serve maritime deployments with its ultra-wide bandwidth. Equipped with high gain LNA, the built-in GPS receiver is ideal for tracking.
Maritime 40G
4x Cellular | 1x GPS
With 4 cellular channels and a GPS, the Maritime 40G is an all-in-one antenna ready to bring unbreakable connectivity to maritime applications. 4x4 MIMO provides solid reliability under heavy usage.
Add-on
Premium Deck Mount
Rugged and heavy duty mounts are intended for deck and mast installations. The cable is protected inside the mount with direct feed through the deck or mast.
Extension Cables
A full array of UV stabilized and low-loss extension cable options with different connectors and lengths to meet any of your antenna needs.
Peplink Antenna Application Brochure
More Possibilities Than You Can Imagine
Discover different scenarios where you can benefit from our antennas,
not just what's implied by their names.
