Bro Pro Family BG
Bro Pro Family Hero
BR Pro Family
The New Benchmark for Professional Connectivity
Icon X65 5G Modem
X65 5G Modem
Icon 5G SA Network Slicing
5G SA &
Network Slicing
Icon PoE+ Input
PoE+ Input
Icon Docker Support
Docker Support
Icon Flexible SIM Options
Flexible SIM
Options
Icon SpeedFusion
SpeedFusion
Advanced 5G Performance
Powered by the X65 5G modem, both routers support standalone (SA) and non-standalone (NSA) 5G modes with enhanced carrier aggregation capabilities, delivering increased throughput and faster speeds across public and private 5G networks.
SA Mode Icon 5G Performance-SA Mode
NSA Mode Icon 5G Performance-NSA Mode
LTE Fallback Icon 5G Performance-LTE Fallback
Private 5G Networks Icon 5G Performance-Private 5G Networks
Network Slicing Icon 5G Performance-Network Slicing
P01 - X65 5G Modem
Higher Peak Theoretical Performance
(On sub-6 GHz 5G)
X65 5G Modem
4.1 Gbps
X62 Modem
3.4 Gbps
Streamlined, Flexible Deployment with PoE Power Input
Power over Ethernet (PoE) input simplifies installation and cabling, allowing the BR1 to be placed in locations with better signal reception, without needing a nearby power outlet.
P02 - PoE input
Smarter Operations with Edge Computing
Run custom applications directly on the device with built-in Docker support and onboard storage, enabling agile performance, seamless integration, and streamlined deployment and management.
P03 - Docker Support
Government-Ready: TAA Compliant
Meet federal and government requirements with full TAA compliance for secure and regulated deployments.
P04 - Taa Compliant
Priority for Public Safety
Ideal for public safety environments, both routers carry AT&T FirstNet and T-Mobile T-Priority certifications and are Verizon Frontline verified, ensuring prioritized and reliable connectivity during mission-critical operations.
P05 - Priority Safety
Flexible SIM Choices for Any Situation
Use eSIM for greater efficiency and instant connectivity, with the option to use physical SIMs when needed.
P06 - Flexible Sim P06 - Flexible Sim
Seamless Failover for Starlink, Fiber, and FWA
Seamlessly integrate 5G with Starlink, fiber, and fixed wireless access (FWA) through SpeedFusion to deliver uninterrupted connectivity. Stay reliably online, always.
P07 - Seamless Failover BR1 Pro 5GK Diagram P07 - Seamless Failover BR2 Pro 5GK Diagram P07 - Seamless Failover BR1 Pro 5GK Diagram P07 - Seamless Failover BR2 Pro 5GK Diagram
Ports and Connections
BR2 Pro (5GK)
P08 - Ports and Connections BR2 Pro 5GK Front P08 - Ports and Connections BR2 Pro 5GK Back
BR1 Pro (5GK)
P08 - Ports and Connections BR1 Pro 5GK Front P08 - Ports and Connections BR1 Pro 5GK Back
