sim-injector-mini-header-pattern-background
sim-injector-mini-only-at-peplink-badge
SIM Injector sim-injector-mini-title-outline.svg
SIM Management from Afar.
sim-injector-mini-point-01-sim-cards.svg
Remotely manage up to 8x SIMs
Integrate up to 8 additional SIMs into your network without the need for physical intervention. Perfect for hard to reach deployments.
sim-injector-mini-point-02-poe.svg
One Ethernet cable is all you need
Power your device through PoE and forgo the need for a nearby power outlet. Power through Microfit Connector is also available for more flexibility.
sim-injector-mini-point-03-sim-injector-mini-top.svg
The best accessory we’ve ever made at only $499*
Durable, rugged, simple to use. At the affordable price of $499*, easy SIM management won’t be gated behind a paywall.
*Pricing applies to US region only, other regions may vary
Ports and Connections
