Antenna Max
Maximum Flexibility, Maximum Gain
Outdoor Cellular / GPS Antenna + Enclosure
Maximum Gain: Up to 6.6dBi
Worried about cable loss?
Minimize cable loss by installing your router directly into the antenna enclosure.
Retain maximum signal gain by connecting the Antenna MAX to the rest of your network with an ethernet cable.
Maximum durability
UV-resistant plastic enclosure resists moisture, water intrusion, salt spray and corrosion
Maximum flexibility
Mix-and-match antenna with many routers including:
BR1 Mini Series*
Transit Duo Pro^
BR1 Pro 5G / CAT-20^
POTS Adapter^ & AP One Rugged
¹BR1 Mini series: BR1 Mini, BR1 Mini Core, BR1 Mini 5G, BR1 Mini M2M.
^For certain products which do not support PoE In, a PoE Splitter is required.
Multiple Mounting Options
Fixed-roof L-mount set included
Wall Mount
Surface Mount
Mounts easily on mobile equipment and vehicles – trucks, vans, boats.
Pole Mount
Maximum value
Antenna MAX is a cost-effective way to get maximum performance from your cellular and 5G routers in outdoor environments
Photos
Ordering Information
Product CodeDescription
ANT-MAX Antenna MAX - 4x LTE/5G, 2x Wi-Fi, 1x GPS 600–6000 MHz, IP67, SMA male (Cellular, GPS), RP-SMA male (Wi-Fi), White
Feature Add - On
Product CodeDescriptions
ACW-651 1" 14 TPI female to Mobility thread for deck mount
ACW-653A 1 1/4" 11 TPI male adapter for deck mount
ACW-420 Gland Accessory Kit
Package Content
  • 1x Antenna MAX
  • Double sided 3M adhesive pad
  • 3x Cable Gland
  • 1x L-Mount Set
  • 2x Hole Plug
Datasheet / Resources
