Antenna MAX S
Rapid Deployment.
All-in-One. 5G + Starlink.
Integrated Antenna Enclosure for Peplink and Starlink
Integration to the MAX
One enclosure. One install. All performance.
The Antenna MAX S takes hybrid connectivity to the MAX by combining the power of satellite and cellular in a single, integrated enclosure.
With built-in 4x 5G/LTE, Wi-Fi, and GPS antennas, you can install your Peplink router and Starlink Mini together with no external RF cables required to virtually eliminate signal loss and maintain maximum signal quality.
Use Peplink’s SpeedFusion to seamlessly bond or failover between Starlink and 5G, ensuring continuous, high-quality connectivity even in areas with physical obstructions.
Durability to the MAX
The Antenna MAX S is engineered for outdoor longevity, built with UV- and salt-resistant plastics, fitted with a metal base for heat dissipation, designed to to withstand high wind loads for fixed or mobile applications.
Convenience to the MAX
Supporting both Power over Ethernet (PoE) and DC input, the Antenna MAX S gives you flexibility in how you deploy. Use the top cover’s watertight clasp system to conveniently secure the Peplink router of your choice:
BR1 Mini Series*
Transit Duo Pro
BR1 Pro Series^
*BR1 Mini series: BR1 Mini, BR1 Mini Core, BR1 Mini 5G, BR1 Mini M2M.
^BR1 Pro series: BR1 Pro 5G, BR1 Pro Cat-20.
Mount it your way with a variety of installation options ideal for vehicles, rooftops, poles, or even custom rack systems.
Surface Mount
Magnetic Mount
Deck Mount
Pole Mount
Note: The deck and magentic mount kits is NOT included in the package.
Value to the MAX
Designed for performance and priced for practicality, the Antenna MAX S delivers an all-in-one Starlink and cellular solution at a price that makes sense for businesses, fleets, and integrators alike.
Whether you’re operating from a remote location, working in an RV, or maintaining mission-critical connections on the move, it saves time, space, and cost – without compromising performance.
Photos
Ordering Information
| ANT-MAX-S | Enclosure with integrated 4x 5G/LTE, 2x Wi-Fi, GPS antennas for Peplink routers and Starlink Mini bundle solution. |
Feature Add - On
| Product Code | Descriptions |
| ACW-651 | 1" 14 TPI female to Mobility thread for deck mount |
| ACW-653A | 1 1/4" 11 TPI male adapter for deck mount |
| ACW-676 | Magnetic Mount for Antenna MAX S |
| ACW-677 | Surface Mount Kit for Antenna MAX Duo / Antenna MAX S |
Package Content
- Antenna MAX S
- L-Mount Set
- Power Supply/ Splitter Mounting Set
- Router Fixation Screws
- 2x M25 Cable Glands
- 1x M25 Hole Plug
- 2x RJ45 Glands
- 2x RJ45 Caps
- 2x Hole Plug
- 1x DC Cable Connector
- 1x 900mm Starlink Power Cable (35.4” / 900 mm)
- 1x Starlink Ethernet Cable (35.4” / 900 mm)
- 1x Ethernet Cable (7.87 ” / 200 mm)
- 1x DC Cable (3.93” / 100 mm)
- 1x Double sided 3M Adhesive Pad
