Back to List
Salad and Go Deployed Restaurant Internet Connectivity in Hours with Peplink Dual 5G
In early 2023, Salad and Go needed restaurant internet connectivity for a new store it was building in the Phoenix area, close to where the Super Bowl would be played. The broadband provider said the line wouldn’t be ready in time, and the build would cost $56,000. Peplink reseller West Networks had it running on dual 5G in under 48 hours, and every new store after it followed the same path.
Summary
Organization
Salad and Go, drive-through restaurant chain (US)
Application
Dual 5G primary internet for new restaurant locations, replacing broadband
Solution Provider
West Networks (Peplink Reseller)
Peplink Deployment
Project Scope
New stores for a 140-location chain adding 50 to 100 stores a year (2023 to 2024)
Outcome
Setup cut from four to six months to hours; up to $20,000 construction saved per site; zero Peplink support tickets in over a year
The Challenge
The Challenge: Restaurant Internet Connectivity Held Back by Broadband Builds
The Solution
The Solution: Dual 5G Package in Place of Broadband at Every Restaurant
The Result
The Result: Months to Hours, Up to $20,000 Saved per Store, Zero Support Tickets
Testimonials
Our store operators love it because we haven't had a Peplink support ticket for over the year we've been using it. It's a full enterprise product and I'd recommend it. I wish I had it years ago. We canceled all future broadband contracts and we've never installed another line since then.
Brian Steele
Deployment Architecture
Featured Products
BR2 Pro
Deployed as the primary internet router at each new Salad and Go store.
Runs two 5G modems for two cellular connections at once.
Supports built-in eSIM and SIM Injector for remote SIM management.
SD Switch 24-Port Rugged
Connected to the BR2 Pro to link the store’s wired devices.
Provides 24 PoE+ ports to connect and power devices over one cable.
Now listed under Peplink Legacy Products; the closest current model is the 24 PoE 2.5G Switch Rugged.
Mobility 42G
Installed in pairs with the BR2 Pro at each store.
Provides four cellular elements per antenna, with 5G band support.
Built to IP68, with panel, wall or pole mounting.
FAQs
Q1. How do two 5G connections keep POS and payment systems online at a restaurant?
A.
Q2. What is the best approach to restaurant internet connectivity for a multi-location chain?
A.
Q3. How much does it cost to replace broadband with 5G at a restaurant?
A.
Q4. Why does a dual-5G setup install in hours when broadband takes months?
A.
Next Steps
Talk to a Specialist
Share Your Story
