Back to List
FINALIST
Deployment Excellence Awards
Flix Keeps Its Fleet Connected Across Borders with Peplink
On a cross-border FlixBus trip, the next carrier’s SIM isn’t on the bus. It’s waiting in a datacenter. Around 1,700 Peplink routers and InControl keep the Flix fleet and its passenger Wi-Fi online, switching carriers at every border from a central pool of more than 700 carrier SIMs, with no one touching the hardware.
Summary
Organization
Flix (global mobility provider, operator of FlixBus)
Application
Multi-carrier cellular connectivity across borders, powering free passenger Wi-Fi with a custom captive portal
Solution Provider
RebelRoam (Peplink Reseller)
Peplink Deployment
Project Scope
Around 1,700 Peplink routers across Europe and the Americas, with more than 700 carrier SIMs
Outcome
Carrier changes at borders with zero SIM swaps, one fleet-wide configuration, and an expansion planned to up to 2,500 vehicles
The Challenge
The Challenge: Every Border Meant Another SIM
The Solution
The Solution: Border Crossings Moved to the Datacenter
The Result
The Result: One Configuration, Zero SIM Swaps, Room to Grow to 2,500
Gallery
Deployment Architecture
Featured Products
Peplink Mobile Router
Dual-cellular router installed across the Flix fleet in Europe and the Americas
Connects to RebelRoam’s central management system for SIM management, using more than 700 carrier SIMs held at its datacenter
Runs the onboard Wi-Fi network that passengers join through a custom captive portal
InControl - Cloud Management
Manages around 1,700 Peplink devices from a single cloud platform
Sets failover and load balancing policies once for the whole fleet, so each router switches to the best available network on its own
Puts new vehicles on the same configuration, supporting growth toward 2,500
FAQs
Q1. How do fleet operators keep passenger Wi-Fi connected across borders without swapping SIM cards?
A.
Q2. How do intercity buses stay connected across borders?
A.
Q3. How do passengers connect to onboard Wi-Fi on a managed fleet?
A.
Q4. How does Peplink InControl support router deployment across a large fleet?
A.
Q5. What does it take to roll out passenger Wi-Fi solutions across an existing fleet?
A.
Q6. What are Peplink mobile routers built for?
A.
Next Steps
Talk to a Specialist
Share Your Story
